1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#773363 08/20/2011 5:51 PM
My 235 engine fires right up but it smokes way to much. What are the causes for this?
ODSS Lawman
ODSS Lawman
There are a few answers we need to help determine your issue.
1. Does it smoke only at start up?
2. Does it smoke only we you let off the gas?
3. What color is the smoke? Black? Grey? White?
4. Odor?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
1. the engine does smoke at start up. 2.When i took it for a test drive there was a huge trail of smoke. the more gas the more smoke. 3.black smoke. 4. odor?, strong classic smoke smell.
H Online: Content
Black smoke is fuel, way too rich. The carburetor is flooding, probably from a piece of trash under the needle valve. A leaky float that is partly filled with fuel will also cause flooding. The engine is probably difficult to keep running at idle, right? Blue smoke is oil, and white smoke is coolant. You probably need to give the carburetor a good cleanout, and install a good-quality inline fuel filter between the fuel pump and the carburetor.
