2 members (59 fleet, KEVINSKI),
157
Mod | | | Forums66 Topics128,034 Posts1,055,551 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | My 235 engine fires right up but it smokes way to much. What are the causes for this? | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | There are a few answers we need to help determine your issue.
1. Does it smoke only at start up? 2. Does it smoke only we you let off the gas? 3. What color is the smoke? Black? Grey? White? 4. Odor?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | 1. the engine does smoke at start up. 2.When i took it for a test drive there was a huge trail of smoke. the more gas the more smoke. 3.black smoke. 4. odor?, strong classic smoke smell. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Black smoke is fuel, way too rich. The carburetor is flooding, probably from a piece of trash under the needle valve. A leaky float that is partly filled with fuel will also cause flooding. The engine is probably difficult to keep running at idle, right? Blue smoke is oil, and white smoke is coolant. You probably need to give the carburetor a good cleanout, and install a good-quality inline fuel filter between the fuel pump and the carburetor. Jerry
