2 members (PAUL Berardi, 78buckshot), 175 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
C4
Offline
Cleaning up the dash and pulling old wires and stuff out. How does the Light switch come out. Can get the collar lose but the knob will not come off to allow it to be taken out the hole in the dash. What am I missing? Thanks
We lust for what we want, and weep for what we need.
Should be a small button on the switch that you push on while attempting to pull the knob out of the switch. This button will be behind the dash and you will just have to feel for it. It will be close to where the shaft from the knob goes into the switch.
Sometimes they can be a little stubborn.
Here are some pictures of the internals of the AD Light Switch:
http://www.pbase.com/dennygraham/ad_light_switch
This one in particular shows the button that releases the knob shaft:
http://www.pbase.com/dennygraham/image/137298629/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I found it works easier if you push and hold the button and then pull the knob.
Of course you've disconnected the battery first, right?
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
No reason to disconnect the battery to pull the knob and shaft out. The shaft is guided by at the front and center so it has to go straight into the insulsted Bakelite sliding block. The only way the shaft is ever gonna come out is if you hold the button in till the end of the shaft clears the detent, which is clearly shown in the pictures.
And yes, of course common sense applies when you get to removing the switch and wires, you surly don't want power to it.
DG
Denny G
Sandwich, IL
Denny - reason to disconnect the battery is if you don't want your headlights on while the shaft is out wink
You can turn them off while it's dangling. Use the knob.
But, It's a good idea when dealing with hot wires to disconnect the battery.
Absolutely! If he's taking the switch out, that hot wire will be dangling loose back there where it could come in contact with anything, creating all kinds of fireworks! NEVER a good idea!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
C4
Offline
Thanks all for the answer, worked like a charm. No power to the system so undoing power not an issue. Would have done that as I don't like getting shocked grin
I love that Denny takes a picture of everything!
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
And I do take a picture of EVERYTHING that I do on the trucks. When you get to be as old as I am, the pictures in your head are just to fuzzy to make out the little details when it's time to put it all back togeather.
DG
Denny G
Sandwich, IL
It also helps everyone else out too.
"The Fake Truck"
