2 members (Thomaslb, Eddie54),
166
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 15 New Guy | | New Guy Joined: Aug 2011 Posts: 15 | Cleaning up the dash and pulling old wires and stuff out. How does the Light switch come out. Can get the collar lose but the knob will not come off to allow it to be taken out the hole in the dash. What am I missing? Thanks
We lust for what we want, and weep for what we need.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Should be a small button on the switch that you push on while attempting to pull the knob out of the switch. This button will be behind the dash and you will just have to feel for it. It will be close to where the shaft from the knob goes into the switch.
Sometimes they can be a little stubborn. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | I found it works easier if you push and hold the button and then pull the knob.
Of course you've disconnected the battery first, right?
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No reason to disconnect the battery to pull the knob and shaft out. The shaft is guided by at the front and center so it has to go straight into the insulsted Bakelite sliding block. The only way the shaft is ever gonna come out is if you hold the button in till the end of the shaft clears the detent, which is clearly shown in the pictures. And yes, of course common sense applies when you get to removing the switch and wires, you surly don't want power to it. DG
Denny G Sandwich, IL
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Denny - reason to disconnect the battery is if you don't want your headlights on while the shaft is out  Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You can turn them off while it's dangling. Use the knob.
But, It's a good idea when dealing with hot wires to disconnect the battery. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | But, It's a good idea when dealing with hot wires to disconnect the battery. Absolutely! If he's taking the switch out, that hot wire will be dangling loose back there where it could come in contact with anything, creating all kinds of fireworks! NEVER a good idea! | | | | | Joined: Aug 2011 Posts: 15 New Guy | | New Guy Joined: Aug 2011 Posts: 15 | Thanks all for the answer, worked like a charm. No power to the system so undoing power not an issue. Would have done that as I don't like getting shocked
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I love that Denny takes a picture of everything! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And I do take a picture of EVERYTHING that I do on the trucks. When you get to be as old as I am, the pictures in your head are just to fuzzy to make out the little details when it's time to put it all back togeather.
DG
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | It also helps everyone else out too. | | |
