7 members (Otto Skorzeny, J Lucas, klhansen, Tronman, electors, 78buckshot, 1 invisible),
106
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | any input? would love to mount under the dash, but most mount in window edges. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There are some postings in the radio sub forum. They seem to work well on FM applications. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used a standard antenna, mounted to the frame under my running boards. Works fine for FM stuff / not too great for AM. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Don - most 'hidden' antennas can't be totally inside the body metal, which acts as a shield against the signal .... a buddy made up a slick plexi "plate topper" to hide his outside the truck, works great Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | IF you can find one, in the '30s GM made an under the running board antenna. It was of course made for AM I have no clue as to whether it would even work for FM but it would be fun to play with one.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I bought a hidden antenna for my truck and mounted it to my bedwood underneath side, it works great. I must add that I do not use my truck in rain or snow. Most of them as stated above need to be away from metal surfaces some (powered versions) will actually short out in those applications. | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Brad, how did you mount it to the bed underside?
~Jim
| | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | Dang. I was going to tuck mine up above the headliner toward the front. Back to the drawing board.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The one I bought on eBay is a small box with the aerial in a 3M tape that sticks like the box to just about anything. Once it is on I don't think you could pull it off. This is the one I bought.
eBay item number 380307647314 this is for reference purposes I have no connection to this antenna other than owning one (they work great by the way). | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Brad, does yours stick to the windshield, if so how could it be a "hidden" antenna?
~Jim
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | No I stuck it to the bedwood underneath then I ran the lead (9' long) up under the cab into the truck. All total it has a 2" by 1/2" box that sticks then a 18" antenna inside plastic that you peel and stick, none of this is visible on my truck.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Do you think it will stay on there through rain, snow, sleet, and sand and gravel? I would think it would get pretty rough under there. Also, does it come with the 9' lead and will the plug fit all radios?
~Jim
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I don't drive my truck except in the summertime on clear, nice days so no I don't think it will hold up under those kids of conditions. Yes the plug on a 9' lead will fit all radios. I will attach a picture up here tomorrow of the install. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is the picture of the antenna in place on my truck, simplest thing to install ever just peel and stick. Don't know if anyone has tried it but I would bet this would work great stuck to the underside of the cardboard headliner with the lead run down the DS post where the wire comes up for the dome light. http://good-times.webshots.com/photo/2281794570102454676JapLms | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks Brad, I believe I'll get one of those. They are cheap enough one could replace it every two or more years. I'll try it out above the windshield first.
~Jim
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i dont have that type but the one i got is junk. it doesnt matter if you hide it or not reception is like a vacuum pump. i got tired of trying to adjust it for reception that i took it off. i use an ipod and get to hear what i want to hear and nothing is in sight. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | What kind are you using, the one that came with the radio? If this doesn't give me reception I'll drill and install an outside antenna.
~Jim
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I just can't imagine not using an outside antenna. What would I do with my Antenna girl? Antenna Girl AAntenna Girl B
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | the one i was using came from custom auto sound. it was powered amplified but like i said reception was poor. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Wow, cut the onions on my hamburger!
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, you need to keep her.
