| | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | can i put 216 intake exhaust manifolod on second series 235 and use 216 alinment rings will it work this truck is not very good shape.thanks | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The port sizes are different between the 235 and 216 but there are adapter rings available from Buffalo and probably many other vendors that will allow this to work. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The carb bolt spacing is also smaller on the 216.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | You could also put a multiple 216 2x1 or 3x1 intake exhaust on a second series 235. Many have done that, too.
There are those who do not use alignment rings at all. Some consider the rings as temporary, and serve no purpose, after the intake is properly installed.
Now if you have bad motor mounts or maybe the exhaust system took a jolt from running over that tree, then the rings would help keep the correct alignment.
Which gasket are you gonna use, 216 or 235.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | what is a 2x1 3x1 intake exhaust.i used a 235 gasket set.ran it 150 miles now have a bad vacume leak hardly runs.i will retiten the manifold see what hapens. | | |
