6 members (Guitplayer, FAST55, fonz8261, 46 Texaco, Shaffer's1950, 1 invisible), 64 guests, and 3 robots.
Topics128,139
Posts1,056,449
Members48,441
#772152 08/16/2011 5:07 PM
can i put 216 intake exhaust manifolod on second series 235 and use 216 alinment rings will it work this truck is not very good shape.thanks
The port sizes are different between the 235 and 216 but there are adapter rings available from Buffalo and probably many other vendors that will allow this to work.
The carb bolt spacing is also smaller on the 216.
My Blog
You could also put a multiple 216
2x1 or 3x1 intake exhaust on a second series 235.
Many have done that, too.
There are those who do not use alignment rings at all.
Some consider the rings as temporary, and serve no purpose,
after the intake is properly installed.
Now if you have bad motor mounts or maybe the exhaust system
took a jolt from running over that tree,
then the rings would help keep the correct alignment.
Which gasket are you gonna use, 216 or 235.
-Tom
1950 Chevy 3100 w/ 1956 235
what is a 2x1 3x1 intake exhaust.i used a 235 gasket set.ran it 150 miles now have a bad vacume leak hardly runs.i will retiten the manifold see what hapens.
