5 members (Johnny Rib, Otto Skorzeny, dwreills, Wickedbass, TooMany2count), 114 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#772164 08/16/2011 6:00 PM
I am installing Fenton Headers on my 59 235. My question is do I need to put a X pipe in the system? Do the two pins that hold the manifold on the ends screw out and replaced with bolts? I and looking at Porter mufflers, has anyone used them and how do they sound on a 235?
Thanks Larry
Well its your choice for the X pipe. Here is a video of a I6 with and without a X pipe. Its a ferd 200 but you will get the idea of difference in sound.
I-6 exhaust with/without an X-pipe
Last edited by Gdads51; 07/15/2025 2:26 PM. Reason: fix video link to remove from embedding in server
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
There is a manifold alignment pin at both ends of the head.
I have taken the pins out of my head and will use bolts. But that is just me.
IMHO:
Forget the "X" pipe, it's not necessary for performance gains with a stock or mild 235 and you'll lose that distinct "Chevy 6 in heat" sound that most of us love.
Porter's and Smitty's have been popular muffler choices to use with Fenton's since back in the 50's. They'll sound great.
ODSS Lawman
ODSS Lawman
The split manifolds are attached via the metal "clips" that are held by boths to the cylinder head. If you are installing an Offy intake are well, you will need to do a little modifying of the clips since the flange thickness is different. SEE HERE
I have some pics somewhere of what I did to make it work. Will have to look around to see where they are......
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
ODSS President
ODSS President
Originally Posted by waldo53
IMHO:
Agree not necessary for performance gains but if you plan to drive your vehicle any distance, lots of 1k and 2k trips like I do that noise gets old remarkably fast. The X-pipe I have has really quieted down my '56 yet it still sounds good.
~ Cosmo
1949 Chevy Half Ton
ODSS President
ODSS President
Originally Posted by Camsore
Gosh, really nice job on the 'X-pipe'. I have old and sturdy 30" glasspacks located after my 'X' and will replace them with Porters one day. The Porters are sturdily built by a small company and their youtube testimonies sure sound good to me. There is a 2-in 2-out muffler that I have seen on the Jegs site that has an X inside it.
PS, I think the paint scheme on your cab is first rate.
Cosmo
~ Cosmo
1949 Chevy Half Ton
thank god i read you're post, i was just getting ready to buy the fenton headers and the offy twin carb setup, for my 46 truck,
Very nice work! In your next set of photos, I hope to see the Pitman arm lock nut installed. I don't want to wake up in the middle of the night thinking about that!!! eeeek
Added new photos with nut installed.
Larry
http://s1189.photobucket.com/albums/z434/camsore/
