1 members (qside),
28
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77171 05/06/2007 11:59 PM | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Hey Guys, Thanks for your help figuring out stuff on my 235. This is a photo of the drivers side of the engine. See those two holes underneath the oil pressure sensor? Does an oil filter get plumbed into them? | | |
#77172 05/07/2007 12:11 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have no clue what it is, but I can tell you it isn't for a filter. The filter would get its supply from a T fitting from the oil pressure port, and return in a hole further up on the block.
Bill Burmeister | | |
#77173 05/07/2007 1:19 AM | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Those are just threaded holes to mount a bracket for clutch linkage on some models. If you clean them out, there will be threads in a blind-bottomed hole, no connection to any oil passages. Jerry
#77174 05/07/2007 1:34 AM | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Cool! I feared that I was going to pump all the oil out of the engine. It's strange that the 235 doesn't have an oil filter as standard equipment though.  | | |
#77175 05/07/2007 3:53 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I'll just bet if you push a putty knife around through all that accumulation of road gunk you'll discover a 1/8npt plug that have been used to eliminate pressure side of the bypass filter.
Just above the bottom lip of the engine is an oil gallery that runs from front to back. This is the pressure side. A couple inches above it is the return gallery...same front to back. That's where your sensor is located.
Above the return gallery, towards the back of the engine is the threaded throttle bell-crank mount where your gas pedal forward motion is changed to up and down motion to work your carb linkage.
Eliminating the bypass filter will pick up 5-7 more pounds of oil pressure. Hope this helps.
Dave | | |
