5 members (68ironhead, Phak1, 49nut, Gray_Ghost, 1 invisible), 64 guests, and 1 robot.
Topics128,049
Posts1,055,691
#771639 08/15/2011 1:33 AM
I found the rearend below , I was told it came from a 56 chevy . I need to do brakes on it before i install it but would like to be more sure so i can tell the parts counter what i need . Can somebody tell from the pictures ?
[IMG]http://i655.photobucket.com/albums/uu278/Smokin54/SANY0197.jpg[/IMG]
[IMG]http://i655.photobucket.com/albums/uu278/Smokin54/SANY0196.jpg[/IMG]
[IMG]http://i655.photobucket.com/albums/uu278/Smokin54/SANY0195.jpg[/IMG]
smokin54 #771644 08/15/2011 1:41 AM
it's correct for 55.2-59, and the brake parts will be the same for any of those years [and most parts fit earlier and later] ... not sure you need to do anything to them if the other side looks the same, except maybe cylinder kits, no need to waste useable parts wink
squeeze #771688 08/15/2011 4:39 AM
Tri-5 Passenger for certain, though the same diff was used in Passenger application up to '64. Ratio could be 3.55, 3.79, or 4.11. Brakes look alright, I do agree with maybe putting an overhaul kit in the wheel cylinders.
Just and FYI, Positraction 3rd members are VERY common for this rearend.
Bill Burmeister
LONGBOX55 #771707 08/15/2011 6:08 AM
Not correct for trucks, but it should work nicely.
