1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | I have a 86 305 motor that has a cracked flywheel. would a flex plate from a 87 305 work on it with a manual 4sp? Or would a 1964 283 flywheel work with the 305? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 86 was a transition year. If it has a 1 piece rear main seal, the 87 will fit. If it has the older 2 piece seal then the 64 will work. . I am confused on the flexplate/manual 4 speed thing. Check the flexplate to make sure it has bolt holes to the converter. There are some variations in those. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i think a flexplate is for automatic trans only. you will need a regular flywheel for standard again i think. philip | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | philip - you are correct in that a flex plate is used with an automatic transmission and a flywheel is used for a manual transmission. Samantha | | |
