2 members (55shaker, Otto Skorzeny), 68 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#770731 08/11/2011 11:10 PM
1 Offline
I have a 86 305 motor that has a cracked flywheel. would a flex plate from a 87 305 work on it with a manual 4sp? Or would a 1964 283 flywheel work with the 305?
Riding in the Passing Lane
86 was a transition year. If it has a 1 piece rear main seal, the 87 will fit. If it has the older 2 piece seal then the 64 will work. . I am confused on the flexplate/manual 4 speed thing. Check the flexplate to make sure it has bolt holes to the converter. There are some variations in those.
1972 Chevy c10 Cheyenne Super
i think a flexplate is for automatic trans only. you will need a regular flywheel for standard again i think. philip
philip t #771129 08/13/2011 3:10 AM
philip - you are correct in that a flex plate is used with an automatic transmission and a flywheel is used for a manual transmission.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
