4 members (59 fleet, mason86, Samantha, dt235sd), 29 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
I put front disc brakes on my 65.I went to put on the wheels,and they did'nt fit.Do I need a different style of wheel?As a newbie I would appreciate some advice.
Did you convert to 6 lug discs or 5 lug? Also, do you want to run the original style steel wheels/hubcaps, or are you looking for something different?
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Its 6 lugs.I was going to get new wheels and tires,so it does'nt matter.
This thread may prove helpful. Post #4 shows the area that normally causes interference between the disc brake caliper and the backside of the stock rim. Sometimes the interference is so minor, a small amount of grinding on the caliper can solve the problem, or a 1/8” or ¼” spacer between the wheel and the rotor may also solve the problem. If this is a desirable option, you just need to make sure the studs are long enough to provide full engagement with the lug nuts.
http://67-72chevytrucks.com/vboard/showthread.php?t=430426&highlight=disc+brake+wheels
Thanks for the help.The posts were a great help!
