1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | I put front disc brakes on my 65.I went to put on the wheels,and they did'nt fit.Do I need a different style of wheel?As a newbie I would appreciate some advice. | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | Did you convert to 6 lug discs or 5 lug? Also, do you want to run the original style steel wheels/hubcaps, or are you looking for something different? | | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | Its 6 lugs.I was going to get new wheels and tires,so it does'nt matter. | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | This thread may prove helpful. Post #4 shows the area that normally causes interference between the disc brake caliper and the backside of the stock rim. Sometimes the interference is so minor, a small amount of grinding on the caliper can solve the problem, or a 1/8β or ΒΌβ spacer between the wheel and the rotor may also solve the problem. If this is a desirable option, you just need to make sure the studs are long enough to provide full engagement with the lug nuts. http://67-72chevytrucks.com/vboard/showthread.php?t=430426&highlight=disc+brake+wheels | | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | Thanks for the help.The posts were a great help! | | |
