| | | Forums66 Topics128,156 Posts1,057,018 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 15 New Guy | | New Guy Joined: Aug 2011 Posts: 15 | the 54 3100 I just aquired has had the front axle converted to disc brakes; with drums on the rear axle (68 camaro). There is no master cyl on the truck or in the parts that came with it. What is the easiest and hopefully least expensive solution for a M/cyl? Want to stay with the stock pedals. Also with the 3sp (64 vintage) what will be needed for the clutch? thanks
We lust for what we want, and weep for what we need.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Easiest is a kit from one of the vendors. Might be cheaper to buy separate pieces. You will need an adapter bracket, a dual master cylinder and a proportioning valve block. I'd buy the kit with power booster. You'll need to custom build brake lines.
Ask your clutch question in the Crashbox Shop. | | | | | Joined: Jun 2011 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 117 | I used the brake booster and bracket setup from CPP. Easy install and I'm very happy with it. You can usually get a discount if you are at a swap meet they are attending. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | On my '53 I moved the m/c up onto the firewall. I purchased the brake pedal assembly from Classic and the booster m/c and portoining valve from CPP.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
