| | | Forums66 Topics128,159 Posts1,057,029 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well things have been a little slow around the ‘Bolt lately so I thought I might throw in a little filler till it picks up again, must be the hot weather keeping everyone away. I was finishing up my fuel/vacuum pump install and had this loose bundle of four tubes running over the top of the engine. Those little factory tube clips are only made to clip the fuel and vacuum advance lines to together and the stock metal tie-wraps that GM used in the later years are a little hard to get as tight as I wanted, besides, I didn‘t have any on hand. Collecting dust in the tool box was this “Clamptite” wire tool that I bought several years ago. It looked interesting at the time but I never found a use for it, till now. I thought I’d give it a try on this bundle of tubes. I guess it doesn’t look to bad and it might even look period correct. Heck, anything has to look better than those dang plastic tie-wraps thttp://www.pbase.com/dennygraham/image/137122829 http://www.pbase.com/dennygraham/image/137122862 http://www.pbase.com/dennygraham/image/137122912Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Denny,
How about a few more photos of all the "terminal ends" of that plumbing?
Nice job, as usual.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As they say down south, that looks gooder'n grits. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | So how does that work Denny? You wrap the wire, use the tool to tighten the wire then snip and fold the end?
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Oh boy, someone else with a clamptite! I've had one for a couple of years, and have used it for all sorts of things. In fact, the rad hose on my Model T has been attached with one of these for 2 years now. I use mine with annealed stainless safety wire. Its like having every size of hose clamp in your tool box. For most thing I just use a single wrap of wire, but for big hoses, I use two wraps. That's exactly how it works Tiny. http://www.clamptitetools.com/ | | | | | Joined: Jan 2009 Posts: 47 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 47 | They are a wonderful tool to have. So much improvement over screw type hose clamps. Have repaired leaking connections on my air hoses with them at the ends where leaks always develop. I think the uses are unlimited for them. Ed | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You are right, I don't have one, but you can betcha I will soon as I can find one. That is just slicker than snot on an onion. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mine arrived on Wednesday. I'll be playing with it soon. Search the Internet for the best price (I posted a link but it has been removed).
| | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | awesome tool denny!!! got one ordered! thanks for sharing, i can think of a million ways to use this! | | |
