0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#77050 05/02/2007 9:11 PM
I filled up my 51 chevy 3100 ('57 235). with 50/50 mix of anti-freeze before starting it up for the first time. After filled up I noticed a good amount coolent leaking out of a small hole on the water pump at 12:00 clock. Is this some type of overflow and what should I do? Thanks guys.
Riding in the Passing Lane
You will have to replace the water pump. The seal is leaking. That is a vent hole.
1972 Chevy c10 Cheyenne Super
2 Offline
Sounds like the shaft seal has dried up. If you run it sometimes it will stop dripping and sometimes it won't. I would run it for a short time and keep an eye on it.
Wrenchbender is probably right about the replacement.
Purney,
Not a vent per se! If the rig hasn't been run in quite awhile, I would fill it, run it and see if the water pump seal will 'self heal' itself. Otherwise it's time for a new pump.
Stuart
Holy cow you guys are great! I am still awed by the speed and accuracy of your answers. If this keeps up I am going to owe a lot of you some Omaha Steaks! I plan on running it sometime over the next few days , will let you know how it turns out.
After my rebuild the same thing happened. After I let it run for a while it "healed" it self.
58' 3200 235 3-speed/OD
