| | | Forums66 Topics128,164 Posts1,057,079 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77027 05/02/2007 2:04 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I've installed a '60 235 in my '42 1/2t PU. I used the short shaft water pump. The fan sits pretty low in relation to the radiator...will this adversely effect its cooling efficiency? The truck appears to run pretty cool in normal conditions, but I haven't really run it hard in warm weather. Comment/thoughts? | | |
#77028 05/02/2007 4:03 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Steve, I have about the same setup as you have. First make sure your radiator is in good condition and clean. The old guy that worked on my radiator also put on a new filler neck so I could use a pressure cap and plugged the overflow on the top of the radiator. (The new filler neck has an over flow built in.) It's just like a modern radiator. If you do this it's important NOT to use more than a 7 lb cap. Any more than that and you will tear out the seams of the ratiator. With this setup the only time my temp guage goes up is when I'm sitting in one place for a long time. I have toyed with the idea of adding a cooling fan on the front of the rad. just for the times when I'm sittin around, but I haven't done it yet. Try out your system as-is in the warm weather and see how it performs. It will probably be ok. George | | |
#77029 05/03/2007 4:00 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | When in doubt, cheat. Have you considered an electric fan? You might have to change the motor if your electrical system is still 6 volt.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
#77030 05/03/2007 5:14 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Short water pumps, electric fans......why not fix it right! Buy the adaptor plate, use the correct "early" style waterpump that has the correct diameter pulley, and get your fan centered on the radiator and forget about overheating problems.
I went through "short pumps", electric fans and finally got it right. In addition to proper cooling, you can get a stock early 216-235 pump from NAPA/Azone/Advanced without sitting on the porch, waiting for the UPS truck! I've got some pics in my album and info on the adaptor plate process. Hope this helps.
Dave | | |
#77031 05/08/2007 2:08 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Fla54...you're right...should have done it correctly the 1st time...adapter plate! For the time being, I'll run the truck as is ...and hope for the best. Thanks for the input. | | |
#77032 05/08/2007 10:17 PM | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Steve,
I originally installed the short shaft water pump on my 235 but after reading and researching here went ahead and switched to the adapter plate. This was done prior to ever turning the newly remanufactured 235 over. It just makes sense to me. Also, like Fl54 said, I did get a new water pump at Advanced Auto.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | |
