3 members (kbenz, JW51, 1 invisible),
218
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 5 New Guy | | New Guy Joined: Feb 2011 Posts: 5 | I have a 62 and there is no evidence that there were seals between the fenders and the cowl. Water, mud and dust are splashed to the door frames, were they made this way?
I have purchased the seals but it is not at all clear how they would mount. They do not appear wide enough to close the gap. Should there be another part? Any info would be helpful.
thanks | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | There was a seal in there from the factory, just most times they are so far deteriorated it's hard to see it.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The '60-'66 Chevy/GMC trucks, Panels & Suburbans had the closure/extension from the backside of the front fender brace, to the front face of the lower cab "A" pillar. There is a rigig metal piece and flexible rubberized piece, one each side. Fender tail dust shields | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | As I recall the metal piece is welded to the fender? Is this true and if so are there other ways to attach.
Thanks HB | | | | | Joined: May 2009 Posts: 47 New Guy | | New Guy Joined: May 2009 Posts: 47 | actually the metal pcs are held on with metal clips | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The metal extension is held on with 4 metal friction clips and the rubber extension is held in place with staples. Like this | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Tony,
Would you have a set for sale, mine are too rust to deal with I think? PM me.
Jake | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I do have a pair, if you still need them. The rubber extension pieces are sold by many of the aftermarket truck parts suppliers. I make my own staples with stainless steel wire, bent to duplicate the factory staples. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Got it. Pm'd you back. Plese let me know if I can help and thanks for the opportunity. Have a great day. | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | i used contact adhesive instead of the staples, and i used plastic "mushroom" fasteners to connect seal metal to fender brace. | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | How are the metal friction clips removed without just cutting them. Or do you have to just cut them. | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | | | | | | Joined: Feb 2011 Posts: 5 New Guy | | New Guy Joined: Feb 2011 Posts: 5 | OK, thanks for the info. I believe someone put new fenders on my truck and failed to install dust seals and also removed the metal extension.
I am going to look for another option to the factory seals because I have no intention of removing the fenders at this point. | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | its a pretty big gap! maybe some closed cell foam like appliances are shipped with? don't know how you will get it in though, maybe remove bottom bolt on fender? | | |
