1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#769 06/12/2002 9:50 PM
Does anyone know a source for the plate that goes between the flywheel and bolt heads? I banged mine up pretty good when I was removing them.I have a 216.
#770 06/12/2002 10:30 PM
Loctite works great . Just be sure to clean the threads in the end of the crank flange.
Porky Pig is just a ham.
#771 06/13/2002 8:32 AM
Don't know of a source. I would either make my own or use red loctite. You don't want the flywheel bolts to come loose.
Fred
52 3600
69 C-10
#772 06/13/2002 8:58 AM
Newer bolts just have a "spike" lockwasher with them and don't use the plates anymore. And locktight is reccommended too by some.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
