| | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Just got back from the Streetrod National at Louisville. Just got to do something about the heat from the engine and other places. Have looked at "Lizardskin", "Dynamat" and others. Wow, they cost a ton of bucks. Does anyone have a more inexpensive way to go? Thanks
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Bill, I am hoping to find something more in line with a thick (10mils) aluminum backing, both sides, with a rubber like inner section. On top of this I would like to place a layer of high density close cell foam that has a thin layer of solf lead or aluminum to mold itself to all the tight corner and such. I found a website called "secondskinaudio.com" that pretty much fits the bill. Just trying to find a better price as these kinds of stuff got to be used in other applications where the puchase price might be lower. Thanks
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | multi layer material like that will not be cheap for any application - lead/foam or lead/felt similar to 2nd skin is commonly used for high end yacht flooring underlay, might try to find some used
Bill | | | | | Joined: Jul 2009 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 23 | A friend of mine goes to wrecking yards and gets the insulation under the carpet of vans and mini vans, then cuts it to fit his needs. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I've purchased the heavy foil backed insulation from an auto upholstery supplier for little money. About 3' x 12' roll as I recall. Good stuff, no name but not expensive. | | |
