0 members (),
106
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76950 05/01/2007 5:23 AM | Joined: Apr 2007 Posts: 6 New Guy | | New Guy Joined: Apr 2007 Posts: 6 | I want to put an open drive line rearend in my truck with the six lug bolt patern. I've been told that the 64 to 69 pickup rear end would fit, but after buying a 66, 12 bolt rear end without my tape I found it to be two inches wider (64 inches wide, where the wheels bolt up to the drum face, instead of 62 inches that is in the 53)
Has anybody had any problems with the difference of widths?
I also came up with a open drive line 55 1st series rear end, rust and all, found in the weeds in the back 40.
If I use it, can a guy find a higher gear set up out of another rear end and what would it be?
Boy was this a mouthful of questions. I hope you can weed through this.
Boardwalk | | |
#76951 05/01/2007 8:53 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | 55 1st is a good rear to use , you can order a 3.3 : 1 gear set from Patricks for $$. | | |
#76952 05/01/2007 12:02 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | I used a 55-1 series rear end in my 53. It is a bolt up deal. I also used a pumpkin from a mid 60's truck with a 3.90 ratio. Works great with my 3 speed over drive transmission. I am currently getting around 21 mpg. on the highway. Tom | | |
#76953 05/01/2007 9:07 PM | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I have a question that relates to this swap, can you just mount a later tailshaft on the earlier tranny? Is it just easier to swap in a tranny from an open driveshaft truck? Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
#76954 05/01/2007 9:52 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | It is easier to swap the transmission from the open drive line. I don't think the intermediate shaft in the transmissions will be the same. | | |
#76955 05/01/2007 10:15 PM | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | over the winter I did the same swap in my wife's '50 1/2 ton truck, I used a 12 bolt rearend from a '67 1/2 chevy truck, it was 62" wide, I also bought a 12 bolt 1/2 ton rearend from a '70 model chevy truck, it was 64" wide, but I just wanted the posi & gears out of it. | | |
#76956 05/02/2007 1:45 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | A tailshaft from a one ton transmission of the same year should fit and will have open drive. | | |
#76957 05/03/2007 12:12 PM | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | Would a trans from a 53 Chevy car fit into a 40 chevy pickup and are they a good match? | | |
#76958 05/06/2007 7:38 PM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | one ich on each side will not make a difference if you run stock wheels no one will notice one inch. i will not tell anyone your wheel is sticking out one inch more if you dont. | | |
