| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | Im getting my Drums turned for my 51' 1 ton and the guy needs to know what specs they need to be turned to.... anybody know? | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Most medium truck drums can go up to .090" above their nominal diameter, so if it's got 11" drums, for instance, the maximum oversize would be 11.090". As a practical limit on a big drum like a 1-ton, you could probably get away with a .125" (1/8") oversize, but that would only work if you weren't planning to ever run with a maximum gross weight. The bigger the drum diameter is machined, the less material there is to dissipate heat. Jerry
