6 members (Uncles51, spanky, texas46, Hotrod Lincoln, Southerntruck, Steelonsteel), 69 guests, and 1 robot.
Topics128,022
Posts1,055,382
Members48,422
#769397 08/07/2011 7:57 PM
Im getting my Drums turned for my 51' 1 ton and the guy needs to know what specs they need to be turned to.... anybody know?
Josh_51GMC #769399 08/07/2011 8:02 PM
H Online: Content
Most medium truck drums can go up to .090" above their nominal diameter, so if it's got 11" drums, for instance, the maximum oversize would be 11.090". As a practical limit on a big drum like a 1-ton, you could probably get away with a .125" (1/8") oversize, but that would only work if you weren't planning to ever run with a maximum gross weight. The bigger the drum diameter is machined, the less material there is to dissipate heat.
