7 members (KEVINSKI, Joe H, Charles in CA, MickeyP, Bill Hanlon, Possum, 3800GUY),
131
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,558 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76933 05/01/2007 5:05 AM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I have a stream of oil leaking out of my hub,its a slow leak,I wiped it down last night and went back to look this morning and the stream was back. It got all over My break pad..you know made a mess.It is a 55 3/4...I am not sure if it is Brak fluid? i am not sure what the hell it is thats leaking, i am not a Mech...but learning as i go. i just dont want to start busting nuts off for no reason..Any Ideas? MIke G
HURRY UP AND WAIT 55 235 3/4
#76934 05/01/2007 5:10 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mike G. Whatever it is you're going to have to 'bust nuts', and after the drum is off, all will be revealed! Stuart | | |
#76935 05/01/2007 5:23 AM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Time to turn on the compressor....I knew it..
#76936 05/01/2007 5:28 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mike G., Are your axle bolts tight? The leak may just be loose axle retaining bolts, try tightening them up first and see how loose they are. Hope that helps. | | |
#76937 05/01/2007 5:34 AM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I will try that..By Hand> Or air tools..
#76938 05/01/2007 7:36 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You are going to have to replace those brake shoes either way.
#76939 05/01/2007 1:52 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Thats what I thought,,(Replace Pads)..they were ready for replace all around. so now is a good time. Time get out my truck Manual..ha ha ha
#76940 05/01/2007 2:10 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Boy...I wish I had some of the 1955 tools they used back then.I guess i will wing it..It does not look to complicated,the manual has a nice exploded view of the wheel hub.
#76941 05/01/2007 3:01 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Mike you said a ¾ ton right, are you talking about a front hub or rear?? I have seen the fronts packed with chassis grease and this will turn to liquid and run back into the inside of the drum when it gets hot. The back could be the seal or gasket leaking allowing hypoid grease into the drum. And you seem to stress “pads”, is this not a stock brake system on your truck, it should have “shoes”. Denny G
Denny G Sandwich, IL
#76942 05/01/2007 3:17 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I meant shoes...sorry, its the Back passanger side, I took off the axle shaft,and there was a metal gasket between the axle shaft and hub,it seemed to have that rubber instant gasket seal on it...there was oil running out at this time. I jacked it up a bit more so the oil would stop running out.I tightend the adjusting nut lock,and I am going to put some gasket seal on the metal gasket before I put the shaft back in. I have a grease gun..should I load it with universal grease at this time? M/G
#76943 05/01/2007 3:29 PM | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | If it's only leaking at the axle flange, not out of the brake drum, you've found the problem. Clean everything up with a solvent like spray brake cleaner or carb cleaner, reapply some silicone gasket sealer (just a small bead) and reassemble it. Those axle bolts need about 65 ft./lb. of torque or so, so don't be timid. You don't need to pack the hub with grease; it's lubed by the rear end oil. Just keep the oil level in the center housing level with the fill hole, so a little can flow down the axle tubes and lube the hubs.
If it's leaking out of the bottom of the inside of the brake drum, ignore all of the above and tear down and replace the brakes, and change the inner grease seal on the hub while you're in there. Jerry
#76944 05/01/2007 3:32 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Awsome...thanks,,1 more Question, all I have is air tools and manual ratchets, i do not have a tourq wrench..What should i use
#76945 05/01/2007 3:42 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mike G. A torque wrench is a very basic tool if you're going to work on your truck, so buy one, or rent one for this job and buy one when you can. As Hotrod Lincoln said the studs must be tight, they transmit all the power from the axle to the hub, hope that helps. | | |
#76946 05/01/2007 3:45 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I agree...I knew i would need one sooner or later..this is probably a good enough reason to buy 1..sure would like to wait til I got down to the Colorado flee market though
#76947 05/01/2007 4:00 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I just noticed something, In my shop Manual it shows them leaving in 2 bolts when the shaft was taken out...Was that important..and will I be able to put the shaft back in and lined up corectly as i didnt leave 2 bolts in the holes like The Illistration.
#76948 05/01/2007 8:44 PM | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Thanks Hotrod...all fixed..I did what you said and no more problem...Awsome...M/G
#76949 05/02/2007 6:14 AM | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Some local parts stores rent Tools.  | | |
