1 members (WICruiser),
209
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | Hi all,
On my 54 the starter is about to go out. It is the original i believe. It will only engage about once out of every 10 trys now. It just whines and doesn't engage the starter. If it is the original do you think it would be better to go ahead and put an all new starter on it or just rebuild the original? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Is it a key switch or foot operated starter. If its a key switch type, you need a new solenoid. If it is a foot operated starter, the starter motor is running before the drive engages. It is either a linkage adjustment, chewed up teeth on the starter drive or a bad spot on the flywheel ring gear. If it is a foot operated starter, check the linkage for movement of the drive before it depresses the switch on the starter. If that looks ok, I would then suspect the ring gear. Turn the engine a little manually and then try to start it. If it starts then you have a bad spot on the ring gear. You can either flip the ring gear, or install a new ring gear. | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | You're not likely to find a new starter for a 1954 engine. They'll all be rebuilt. It sounds like you've got a bad starter drive, (sometimes called a "Bendix") It's an easy swap that doesn't require reworking the whole starter. Jerry
| | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | It is a foot operated starter. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now teach', that should read, (sometimes improperly called a "Bendix")
I'd bet you've just got a bunch of slop in that linkage as Ken brought up. I've seen fixes on old farm trucks where old chunks cut off a tire were tied on to the fork with bailing wire to get it to ingage.
DG
Denny G Sandwich, IL
| | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | I took the starter off this morning. The ring gear shows a little wear, but nothing i would think that major. The corners of each tooth are worn, and it looks to be fresh, bright shiny metal and was some fresh shavings. The teeth on starter look fine. There didn't seem to be a lot of slop in the linkage, but am i right in thinking it may not take much? There does seam to be some in the pivot arm on the starter that depresses the switch, it has some movement before it depresses the switch. The teeth on the ring gear look to me to just be a very small corner taken off of the teeth, not enough not to engage the starter i would think. I'm not a mechaninc and i really appriciate the help guys. So would you think maybe just tighting up the linkage would do it? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes, if the teeth aren't chewed up and the Bendix (improper term) is working properly, if you can take the slop out it should engage. If the switch contacts (about ten bucks) are burned away badly then that may a reason it is not engaging. Here is an example of how one creative old farmer was able to put off replacing his switch: http://www.pbase.com/dennygraham/image/131215242/large Denny Graham Sandwich, IL
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Yes, but,You might save yourself a lot of grief by just installing the rebuilt starter. | | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | It looks as though the switch has already been replaced at least once, it looks rather new, except the button is rusty. I'm wanting to make it onto a daily driver so i think i may just replace the starter with a rebuilt one just to be sure. Thanks for all the help.  | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | While you've got the starter out, do yourself a favor and change the drive unit with the gear on it. There's a one-way clutch in it that causes the identical symptom you're describing when it starts to slip. It would take a horrendous amount of slack in the linkage to get the armature turning before the starter drive engages with the flywheel. Jerry
| | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | Jerry, are you refering to the drive unit with the gear on it within the starter? | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Yes, that's what I've been saying repeatedly. If you reinstall it without changing that piece, you'll just be putting the problem right back in there. The starter drive has a one-way clutch built into it to avoid overspeeding the starter armature when the engine fires up. Once the clutch begins to fail, it can freewheel both ways occasionally, and the starter shaft spins without turning the flywheel. The clutch will catch occasionally, and work right for a time before it fails completely. Jerry
| | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | That sounds exactly like what it is doing. Thanks.
Darren. | | |
