7 members (Guitplayer, Otto Skorzeny, Perro, greenie-reddy, Hush, Hotrod Lincoln, 1 invisible),
160
Mod | | | Forums66 Topics128,108 Posts1,056,228 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 6 New Guy | | New Guy Joined: Jul 2011 Posts: 6 | I have a 54 3800 and need new drums. From what I have read they are hard to find. Is there a source for these parts? Also can you buy pistons for the wheel cylinders? Just bought truck that has sit for 40 years and bring it back to life. Engine was first and it now purrs, dirt dobbers sealed the intake/carb and other than rebuilding carb, and replacing wiring/ign parts it came back to life. Some things I am finding are really funny, a finnishing nail was used a cotter pin in fron axle. JMS | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | You should place your query in the Parts Wanted section. Someone may have some to sell, and maybe even nearby! As for the pistons for the wheel cylinders, I believe you can find complete rebuild kits that include the spring, pistons, and cups.
I loved looking through my old farm truck when I bought it. Still get a kick out of some of the things I found. For example, I found an old Hires Root Beer bottle opener in the ash tray. That's a keeper! I also found old beat up license plates were used to plug holes in the wood flat bed it had. Out of state and rusted through. Too bad.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The drums are really tough to find. You could try the parts wanted here and also on the VCCA site. Another source would be wrecking yards. I would measure your drums to see if there is any life left in them. You may be able to substitute a rear axle from a later truck, one that you can get drums for. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | You might double check me but I recall the rear drums on a 1 ton are the same as the front drums on a 1 1/2 and 2 ton.
Bruce | | | | | Joined: Jul 2011 Posts: 6 New Guy | | New Guy Joined: Jul 2011 Posts: 6 | Is there anyone who needs new brake drums. I found a source to reproduce them. If there was enough of a demand the price would not be to bad ($180). Anyway just trying to check all angles.
JMS | | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | What qualifies as "enough"
1950 3804 Pickup
| | | | | Joined: Jul 2011 Posts: 6 New Guy | | New Guy Joined: Jul 2011 Posts: 6 | It would probably take ten sets.
JMS | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | If you can get the interest - put me down for a set.
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Does anyone know if the rear drums on 3/4 tons are the same as the 1 ton fronts?
JohnSabol...if you want more interest, see if you can get the information out there in a "sticky note" here in the forums. Right now my drums appear OK but I might be persuaded to buy extras.
Kyle | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Kyle, Though both are 12" diameter I believe they are different. Rear drums usually have more of an offset.
A general FYI for this thread, keep in mind that '46-'52 drums will be different than '53 and up. 1953 was the first year for the Bendix style brakes on these trucks. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I want my name on the list for 2 rear drums for a 1951 single wheel 1 Ton. I hope this list grows because having new drums available would be amazing! | | | | | Joined: Jul 2011 Posts: 6 New Guy | | New Guy Joined: Jul 2011 Posts: 6 | I guess it is also the matter of exactly what is needed and if older truck drums are compatible. On mine it has 14" rear drums that have an outside diameter of about 15.75" and a total depth of 5.125", they have 8 lugs on a 6.5" circle and a 4.5" pilot hole, also have two cs holes to hole the drum to the hub and four other holes that I don't know their use. Does anyone know if the older Huck style brakes use the same drums?
JMS | | | | | Joined: Jul 2011 Posts: 6 New Guy | | New Guy Joined: Jul 2011 Posts: 6 | To add information, it appears that 46 - 52 one tons take pn 809808 for a rear drum and 53 and 54 take pn 3703616. Not sure about compatibility, probably not, probably why these are obsolete.
JMS | | | | | Joined: May 2011 Posts: 189 'Bolter | | 'Bolter Joined: May 2011 Posts: 189 | It's great to hear about a possible source for these drums. My truck is a 1950 1 ton 3804 with the 9' box. I was fortunate enough a few years ago to find a NOS set of rear drums, and I did not hesitate to purchase them. I know there are several people that would like to see these come available. I would like to know if there is the same level of interest for the front drums. Those I would be interested in finding. I hope someday we have a source for the fronts drums. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | It's great to hear about a possible source for these drums. My truck is a 1950 1 ton 3804 with the 9' box. I was fortunate enough a few years ago to find a NOS set of rear drums, and I did not hesitate to purchase them. I know there are several people that would like to see these come available. I would like to know if there is the same level of interest for the front drums. Those I would be interested in finding. I hope someday we have a source for the fronts drums. Are the 1 ton front drum's not same as the rear of a 3/4 ton? | | | | | Joined: May 2011 Posts: 189 'Bolter | | 'Bolter Joined: May 2011 Posts: 189 | Bigtonka,
I beleive the diameter & the width of the shoe contact area is the same, but the rear drums have more of an offset because of the hub on the rear axel. In other words, if you laid one of each on the floor, the drum for the rear would be taller than the front drum. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't thick the Huck drums are the same as the next generation. | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Put me down for a set of drums for a 'pre'53 3804 (SRW).
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | I'll take a set. 1950 3804
1950 3804 Pickup
| | | | | Joined: Jul 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 59 | I'll take a set (front and rear, if possible): '48 GMC 250 (1-ton) | | | | | Joined: Mar 2023 Posts: 82 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 82 | I know this has been dead for awhile but has anyone found a current source for 14in rear brake drums for the 3800's? | | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | As far as I know there is no after market source for the drums! If you can find any at a used lot scoop them up they are very rare to find. | | | | | Joined: Mar 2023 Posts: 82 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 82 | So I spoke to a company called DuraBrake and they can make custom/made to order brake drums. Minimum order qty is 12 and the person on the phone rough quoted about $450 a piece....I am curious if any one of the parts companies (LMC, Chevys of the 40's, etc) would be interested in going into a larger lot size to reduce cost, or if we had enough interest here for them. But for $450 a piece its same or cheaper to swap the entire rear axle at that point.... | | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | I've had no problem finding used drums but in my neck of the woods the 3/4 and 1 tons were super common back in the day. Seems like lots of these trucks didn't really see a pile of miles so there's lots of drum left. There's enough of them out there still that i wouldn't want to fork out for custom made ones.
4.10 gearsets on the other hand..... | | | | | Joined: Mar 2023 Posts: 82 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 82 | Thorens, If you know where someone can get drums, would you mind helping out finding some more?
| | | | | Joined: Sep 2021 Posts: 2 Moderated | | Moderated Joined: Sep 2021 Posts: 2 | I'm also looking for rear drums for a 1 ton. Mine are worn too far to get machined. | | | | | Joined: Sep 2009 Posts: 5,886 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,886 | Steelbee, You need to post an ad in Truck Parts Wanted forum. Make sure you specify, make. model. year in your title or description to help folks know what you are looking for. Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Maybe someone can verify this ...
I've heard anecdotally that because the HO72 axle (for our 1-tons) was made all the way through the late '60's, you might be able to retro fit the newer Bendix style backing plates, shoes, mechanisms and drums from a newer HO72 to an older one.
If you can find a '68 3/4-ton truck with an automatic transmission and coil springs in a junkyard, there is *possibility* that you can find the 4.10 gearset as well as better brake components ... i.e., grab the whole axle.
But this needs verification.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2023 Posts: 82 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 82 | Just as an FYI I have a singular brake drum and a set of brake pads for sale. PM me if interested. | | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Just as an FYI I have a singular brake drum and a set of brake pads for sale. PM me if interested. Good morning, just a reminder that all communications using the words "for sale" should be conducted in the Swap Meet Forum, Truck Parts for sale. A way to avoid this being in issue is to ask person to PM you and leave the "for sale" out of the sentence. Thanks, hope you are able to help your fellow bolter out!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | |
