1 members (NJC),
78
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 22 New Guy | | New Guy Joined: Jul 2011 Posts: 22 | I've been trying for weeks to get the center radio grille removed from the dash. I got so frustrated with it yesterday that I took a sawzall to one of the bolts and scratched up the dash - one more thing for me to fix! That's my own fault. They're so rusted on in the back and such tiny nuts - seems to fit a 10 mm socket without having a clear visual from the back. Can't get the darn things off! Anyone else have this problem and how did you get it off?? I'm going to just end up cutting the whole thing and then I'll to replace it. Thanks | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I did this not too long ago - I can't remember the size - but they're not metric! I shot most of my bolts with PB Blaster before removing, came off w/o a hitch.
Of course I was on my back with my head squeezed up the firewall.
Remove the glove box to give you some leverage if you haven't.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | for sure not metric, but I also can't recall the size, maybe a 1/4 or there about, just get you a hand full of the smaller ones and go... sort of a pain in the butt, but if a 60 plus yr old man at the time I removed mine I am sure you will get er done Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are 1/4" there are also two small clips in the center top and bottom that if there will need to be pried off. If you don't soak them and you cut them or they come loosed of the spot weld the grill trim pieces will be junk they cannot be repaired as far as I can see. | | |
