4 members (Wayne67vert, Gray_Ghost, BC59, 1 invisible), 155 guests, and 2 robots.
Topics128,164
Posts1,056,965
Members48,458
i have a 95 LT1 w/4EL60 trans that i am putting in a 66 carryall,my problem is trying to keep the electric speedo for the painless wiring computer to operate PLUS have a manual speedo for the stock speedometer in dash, does anybody make some kind of adapter to use both ?
Currently cruising
in the
Passing Lane
Double post oops
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Try GMCOPO www.gmcopo.com they have a VSS adapter I think will work for your application .
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
Take a look at the CableX Box from Abbott. Have one in my 47 with an electronic T-5. Fully adjustible and simple to install. http://www.atrol.com/cablex.htm
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
