7 members (Otto Skorzeny, GrandpasJimmy, Hotrod Lincoln, BarryP, 78buckshot, Mike Roache, Gray_Ghost),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,924 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76870 04/30/2007 6:08 AM | Joined: Mar 2000 Posts: 137 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 137 | i have a 95 LT1 w/4EL60 trans that i am putting in a 66 carryall,my problem is trying to keep the electric speedo for the painless wiring computer to operate PLUS have a manual speedo for the stock speedometer in dash, does anybody make some kind of adapter to use both ? | | |
#76871 04/30/2007 3:07 PM | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | | | |
#76872 05/01/2007 2:20 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Try GMCOPO www.gmcopo.com they have a VSS adapter I think will work for your application .
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#76873 05/07/2007 5:19 PM | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | Take a look at the CableX Box from Abbott. Have one in my 47 with an electronic T-5. Fully adjustible and simple to install. http://www.atrol.com/cablex.htm
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
