1 members (Danielbolt), 163 guests, and 4 robots.
Topics128,149
Posts1,056,818
Members48,454
i have a 95 LT1 w/4EL60 trans that i am putting in a 66 carryall,my problem is trying to keep the electric speedo for the painless wiring computer to operate PLUS have a manual speedo for the stock speedometer in dash, does anybody make some kind of adapter to use both ?
Currently cruising
in the
Passing Lane
Junior Member
Junior Member
I know the 4L60E is pretty much the same thing as a 700r4 trans, which had some manual speedos.
i assume you typed the trans wrong, as it should be a 4L60E in an lt1, which may be why you cant find anything, but i could be wrong. I found this in a google search
http://www.shiftworks.com/tailhousing.htm
I would convert to mechanical & then use a speed sensor from 85-87 C10/85-92 R10 truck, it was mounted to the back of the speedo, prolly easily adapted to the 66 unit.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Here's what I used, http://www.abbott-tach.com/cablex.htm So far so good and real easy to install.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
