4 members (papas52, Canadian Dump, Gray_Ghost, Hotrod Lincoln), 111 guests, and 3 robots.
Topics128,165
Posts1,056,987
Members48,458
I'm about to start the process of jetting the 32/36 Holley Webber Carb purchased from a popular vendor. Given the costs of weber jets and emulsion tubes would anyone be willing to share what worked on your 235 at sealevel up to 5000feet: Primary and Secondary Mains. Primary and Secondary Idle. Primary and Secondary Airs. Primary and Secondary Emulsion tubes. Lots of information on the web for foreign cars however nothing for cyl capacities approaching ours.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
Its amazing that with all the holley webers sold by a popular vendor to the people on this site that nobody has taken one apart and rejeted? I have one just about figgured out and will post what I find.
Apprentice
Apprentice
Keep us posted. I'm very interested to find out your results.John
Tim,I used dual Holley Webers on a moderately tuned 261 a few years back,M4F cam,Fentons,more compression.The stock main jets were fine,went up one size in the low speed or pilot jets to eliminate an off idle stumble.This was on a heated intake.I don't remember the main jet number,and I don't know if all the old H/W's have the same jetting,so try em and see if they carburate ok,I bet the main jets will be real close as is.
After fiddling around for a month or so here's my Sealevel jetting on a .060 over 235, Howard's 3/4 cam set at .012 & .014. Single Holley/Weber 32/36 carb on a heated intake. Fenton headers. Petronics ign. Holley low pressure regulator set at 4 lbs. Main jets are; primary 147, secondary 150. Air Correction Jets;primary 160, secondary 165. Idle Jets; primary 70, secondary 65. Emulsion tubes; primary F6, secondary F50. Pump jet 50. Tail pipes are slightly gray, crisp sound to engine. You may have to go with a 145 as 147's are hard to find. Carbs unlimited in Auburn , Washington at 1-800-994-CARB have the best prices on jets, quick delivery.
Update with jetting the Holley Weber 32/36 Carb from Langdon: Still fiddling however now getting 20 mpg. Idle jets 75 & 50, Air 185 & 170, Mains 132 & 147, Emulsion Tubes F6 & F50, Pump 50. SeaLevel setting.
I've been tinkering around with 5200 series HW carbs for a while and I've gone to the 5210 HW for my 235. I presently am using: main 145 secondary 160, main air corrector 190 secondary 190, primary idle jet 65, secondary idle jet 70. f6 emulsion tubes. I have a tendency to be generous in fuel mix as to protect from excess heat. Getting a new aluminum radiator soon and can jet down for more economy. Found low cost jets overseas, $2.50 for mains. Check ALPHA 1750's carburetors parts store. Check out fordsix.com holley/weber jetting tips. Really good starting points.
