6 members (JW51, 55shaker, moparguy, Cosmo, Gdads51, 1 invisible), 108 guests, and 2 robots.
Topics128,069
Posts1,055,896
Members48,428
#768216 08/03/2011 3:12 PM
can somebody tell me how to remove this upper door molding on a truck?dont want to bend it up ? also are all of them identical 55 -59 ? thanks mike
Currently cruising
in the
Passing Lane
if you mean the outside window trim, see here, mostly just press in clips, but appears to be a couple bolts at the ends .... yes, the 55-59 window trim was the same
