8 members (Gdads51, frogfarmer, Hotrod Lincoln, rfs56trk, JoeDude, Jon G, TexasA&M48Truck, dt235sd),
139
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 22 New Guy | | New Guy Joined: Jul 2010 Posts: 22 | Hey guys, I'm going to purchase a set of stainless outside mirrors to put on the doors of my 66' GMC Burb. Currently have a crappy, cheap set on them. How do I find out the exact dimensions to place the base of the mirrors? I am worried about them looking correctly. Any advice would be greatly appreciatedd | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | All light-duty turck driver side doors have a weld plate with three threaded holes, to receive the sport-style mirror. Sometimes they are welded up or filled with body filler, but they are still visible from the inside of the door shell with the innder door panel removed. Additionally, the passenger side door shells have a reinforcing plate in the mirror area, with three holes drilled in it, that is also visible from the inside of the door shell with the inner door panel removed. These three holes are not threaded, nor do they have a weld nut, but they are in the proper location, as determined by the factory reinforcing plate on the inside of the door skin.
If you locate them, in a location other than where these holes are, you run the risk of hitting half the hole and wallowing out the outer sheetmetal skin, when the bit tries to run into the factory holes. | | | | | Joined: Jul 2010 Posts: 22 New Guy | | New Guy Joined: Jul 2010 Posts: 22 | Thanks Tony, I've not had a chance to remove the inside door panel yet but I was hoping there would have been some type of reinforcement bracket. If this is the case then I should be able to maybe drill the holes out from the inside. Thanks again.
| | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | My 66 gmc had the reinforcing plate on the passenger but no nuts so we drilled them out and bolted it into place. Kieth
we used the new mirror as the pattern to check the plate with.
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Tony How does one mark on the (exterior) the location to drill the holes so as to make sure alignment with passenger side backing plate. I have found the passenger side backing plate and the 3 hole pattern but have not figured out how to transpose the location to the exterior to mark for drilling. If you have a method. HB | | | | | Joined: Sep 2001 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 36 | I measured to find one hole and drilled it. Then I used the mirror base as a template to drill the other two. | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Will a right angle drill and a short bit work from the inside, working on my 65 jimmy and would like to use the stock appearing brackets with the larger SS heads, thanks.
You Learn more Listening than Talking
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Right-angle drill & short bit is one way, as mentioned by Squareparts2. You can also use a spring-punch from the inside. It will put a very small divot in the metal, from the inside, that can be picked up on the outside. After finding the first hole, I use a Unibit from the outside to find the first hole. Carefully drilling out the hole with a Unibit, will find the center of the first hole, relative to the backing plate. The rubber mounting pad, serves as a good template for the other two holes.
Backing up these bolts can be a bit daunting, so using a Riv-nut is also a good solution, in lieu of a sheet metal screw or bolt & nut. Riv-nuts and the setting tool are available at most well-stocked hardware stores. I don't recommend using sheet metal screws, since they are prone to pull out. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | The bottom hole on the reinforcement plate is threaded. Perhaps running a bolt with a sharpened tip through the hole into the fender enough to dimple it would mark the spot to drill the finder. This would insure that the mirror bolt will thread up correctly with the plate.
Use a spring punch through the upper hole to dimple the fender. Then mount the mirror with the "threaded" bolt to fine-tune the location of the upper hole. It may not be exactly on the dimple.
Just a idea. I haven't tried it.
My truck's po drilled from the outside without using the reinforcing plate to mark the location. This resulted in an extra upper hole in the reinforcing plate and buggered threads on the lower hole.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | thanks for the ideas. Gives me a new strategy.
| | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | We used the spring punch method finding 2 with the punch then the third with the mirror. worked great. Kieth
918-446-2245
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Off to get a spring punch. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Went looking for a spring punch. No luck yet, but I have not the good spots yet. But as I probed the inside of the door panel, finding the reinforced hole area, How do I get the punch and my hands in there to center the punch and make the mark. I suspect there is an easy answer that will lead me to hit myself for asking the question.
HB | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
