Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Bill Hanlon, Otto Skorzeny, Gdads51, Cosmo, MickeyP), 59 guests, and 0 robots.
Topics128,007
Posts1,055,279
Members48,418
#768049 08/03/2011 1:02 AM
What use do I have for a seized (sp?) engine? I was given the news today that it's definitely a goner. What should I do with it? Scrap metal?
JTKimothy #768087 08/03/2011 2:37 AM
What kind of engine? If it's a small block V-8, it's probably junk because there are so many of them available. A full-pressure 235 might be worth saving if the block isn't cracked or some other major disaster is present. The most common cause of a locked-up engine is piston rings rusted to the cylinder walls or a spun rod or main bearing. All those things are repairable, just expensive. An engine rebuilder might give you a few bucks for the engine as a "rebuildable core".
JTKimothy #768088 08/03/2011 2:37 AM
It might help if we knew what the engine is. If it's a stock '50 216 there are better choices.
JTKimothy #768092 08/03/2011 2:44 AM
There are goners, and then there are goners. If it is frozen up from sitting, the cylinders and rings have rusted, and may be freed up with kroil, kerosene, or some other penetrant. Might be salvageable. BUT, if it is really seized and not just stuck, as in OVERHEATED meltdown, scored cylinders, burned up bearings and such, it may not be worth the effort and cost to mess with. But still, somebody may want the head, manifolds, etc., so it has some value. Maybe only scrap value. Might try post in parts for sale section, with an honest description, and see if anyone's interested. Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #768108 08/03/2011 3:07 AM
This lady had previously posted pics of her engine. See the link. I think it's good advice to scrap it. The potential to salvage the engine is slim and would be very expensive.
Kim, I would shop for a decent engine. They often appear in the ads on Stovebolt. Reading your blog, don't quit yet. We all know
how overwhelming restoration can be at times. Don't look at the big picture just yet. Take baby steps.
http://s71.photobucket.com/albums/i135/jtkimothy/1950%20Chevy/Under%20the%20Hood/
Drew
DrewP #768114 08/03/2011 3:17 AM
I'm with Drew, looks pre-conditioned for use as a salt water boat anchor .... there's a range of engine possibilities that would be preferable and you've put some good work into the truck already, just keep at it, good things take time
squeeze #768134 08/03/2011 4:33 AM
Strip the parts and salvage the rest. Manifolds, starter, head, bolts, pan etc. Priced out individually they will cost you several hundred dollars to replace. If you have room to park it in a corner, you could scrap it later. The later 235 engines in your area come up often on craigslist.
GMONIZ #768339 08/03/2011 11:33 PM
Hey Drew, that lady was me smile Yup that's my rusty pile of scrap metal!! Gonna start taking it down and scrapping for cash to turn back into the truck. Thanks for the advice guys!
