0 members (),
37
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 22 New Guy | | New Guy Joined: Jul 2011 Posts: 22 | What use do I have for a seized (sp?) engine? I was given the news today that it's definitely a goner. What should I do with it? Scrap metal? | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | What kind of engine? If it's a small block V-8, it's probably junk because there are so many of them available. A full-pressure 235 might be worth saving if the block isn't cracked or some other major disaster is present. The most common cause of a locked-up engine is piston rings rusted to the cylinder walls or a spun rod or main bearing. All those things are repairable, just expensive. An engine rebuilder might give you a few bucks for the engine as a "rebuildable core". Jerry
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It might help if we knew what the engine is. If it's a stock '50 216 there are better choices. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | There are goners, and then there are goners. If it is frozen up from sitting, the cylinders and rings have rusted, and may be freed up with kroil, kerosene, or some other penetrant. Might be salvageable. BUT, if it is really seized and not just stuck, as in OVERHEATED meltdown, scored cylinders, burned up bearings and such, it may not be worth the effort and cost to mess with. But still, somebody may want the head, manifolds, etc., so it has some value. Maybe only scrap value. Might try post in parts for sale section, with an honest description, and see if anyone's interested. Good luck!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | This lady had previously posted pics of her engine. See the link. I think it's good advice to scrap it. The potential to salvage the engine is slim and would be very expensive. Kim, I would shop for a decent engine. They often appear in the ads on Stovebolt. Reading your blog, don't quit yet. We all know how overwhelming restoration can be at times. Don't look at the big picture just yet. Take baby steps. http://s71.photobucket.com/albums/i135/jtkimothy/1950%20Chevy/Under%20the%20Hood/
Drew
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I'm with Drew, looks pre-conditioned for use as a salt water boat anchor .... there's a range of engine possibilities that would be preferable and you've put some good work into the truck already, just keep at it, good things take time
Bill | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Strip the parts and salvage the rest. Manifolds, starter, head, bolts, pan etc. Priced out individually they will cost you several hundred dollars to replace. If you have room to park it in a corner, you could scrap it later. The later 235 engines in your area come up often on craigslist. | | | | | Joined: Jul 2011 Posts: 22 New Guy | | New Guy Joined: Jul 2011 Posts: 22 | Hey Drew, that lady was me  Yup that's my rusty pile of scrap metal!! Gonna start taking it down and scrapping for cash to turn back into the truck. Thanks for the advice guys! | | |
