7 members (Jon G, DadsFirstPickup, dt235sd, TUTS 59, RLB, Otto Skorzeny, 52Carl),
166
Mod | | | Forums66 Topics128,130 Posts1,056,714 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 29 New Guy | | New Guy Joined: Jul 2011 Posts: 29 | im lookin to ship a 46 2 ton. dont have specs of the rear tires and i need to tell the shipper to see if it'll fit on their trailer. anyone know off the top of their head?
| | | | | Joined: Jul 2011 Posts: 29 New Guy | | New Guy Joined: Jul 2011 Posts: 29 | correction, the total width of the rear axle | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It will fit any normal trailer that is made for the weight. If the outer tire/wheels are removed it will fit between the fenders so it should not be a problem at all. | | | | | Joined: Aug 2001 Posts: 3,608 Moderator | | Moderator Joined: Aug 2001 Posts: 3,608 | 79 and 9/32"? Jake You must be a Machinist to even know what 79.28125 Thousands is! Money Pit speaks the truth and watch the weight to trailer, tow vehicle hauling capacity. Round it up to 79 and ½ inches and you will be fine as long as the tow vehicle and trailer are rated for the weight to carry a 6,000 + pound truck.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | The 79 9/32" is the center to center width of the outside dual. My '46 1.5ton measures about 86 1/2" outside-outside of the duals. A 1.5/2 ton truck will not have the duals sitting fully on the bed unless it is a deck-over trailer. The front wheels should fit between the fenders, but the outside duals will not. As mentioned, the outside wheels could be removed to make the rear narrower.
That is a really good resource though. I had come across the site awhile ago, but had forgotten about it.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | When I brought home my big bolt I hauled it on a trailer that had the fenders sticking up on each side. The outside dual on each side rested on the fender. This proved handy as I chained the front down first, snugging the rear up against the fenders, I then chained the rear. I probably didn't need it but it was reassuring knowing the rear was somewhat chocked against the trailer and couldn't walk around on the deck.
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
