1 members (klhansen),
65
Mod | | | Forums66 Topics128,090 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Hi there,
I have a '54 Chevy 3100 truck with a 12v conversion. I have not been able to get any spark, though the engine turns.
I recently moved over to a Pertronix Igintion Coil and Electronic Points. I went to start the truck and it sounded like it wanted to spark, then quit.
I tried again and it did not turn at all...the horn merely made a clicking sound. I think I may have shorted the system.
An admitted novice I know very little about this engine as it is my first experience working on it. I am looking for advice on how to sleuth out the short.
I also heard from my local Auto parts dealer that the Pertronix coil needs a separate line running from the dash to the coil to make sure 12v is going to the coil. is this true?
i appreciate any help.
Cheers,
Carlos | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Carlos,
Charge the battery. How new is it?
Did the engine start before you put in the Pertronix unit?
What is the condition of the ignition wires, rotor, cap, and coil?
What is the part number for the Pertronix unit you are using?
What kind of coil are you using (voltage and brand)?
Do you have a ballast resister in-line to the coil?
I'd use normal points/condenser (set properly) and first get the engine running. Then, I'd try out the Pertronix unit.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ruckin Chevy, it sounds to me like you have a bad connection in the positive or ground circuit, check all your large cable connections beginning with the battery. I have installed quite a few Pertronix conversions, and I have never had to install anything that did not come in the kit. | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Clean the battery terminal connections. A short creates a high-current discharge and burns wires of blows fuses. What you've got is an open circuit, not a short. Jerry
| | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | WOW...thanks for all the replies. Here is what I know...
The battery is brand new and fully charged, I have it on a trickle charger.
The engine never started before the pertronix points (1168LS) which is why I moved to it. the engine was turning before...but there was no spark.
the wires are brand new...plugs are brand new...cap and rotor are new...ignition coil wire is new. the coil is the Pertronix flame thrower (40511...12V with internal resistor).
I will check my hard connections since the lights work but the horn clicks. I am dumfounded because it worked for two tries and then crapped out on the third.
I will check on the open circuit issues and let you know what I find.
Cheers,
Carlos | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If your bat is strong & all the cables & connections are good, you probably have a bad starter or the switch on top of it. Wire the petronics acording to the directions. Some models retain the resister & some dont.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Would the horn still be able to sound if there is a bad starter? I am really perplexed here because it was turning with the new Pertronix points and coil, then on the 3rd try there was nothing.
Here is what I have that is 12V: Battery, generator, starter, coil. am I missing anything to have a full 12V system? I ask because I am wondering if the system was never fully converted before and I need to make the full conversion. | | | | | Joined: May 2010 Posts: 20 New Guy | | New Guy Joined: May 2010 Posts: 20 | Hy Ruckin Chevy, it sounds to me like you have a bad connection in the positive or ground circuit, check all your large cable connections beginning with the battery. I have installed quite a few Pertronix conversions, and I have never had to install anything that did not come in the kit. I am with 3B on cleaning EVERY connection in the path from the battery to the starter. This includes chassis ground straps, and the negative battery connections. If you have the repair type battery terminals just go buy new cables of at least 2ga or thicker.
Ted My ride but looking for a Deco Bolt for the wife.
| | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Carlos
You have made so many changes that I am sure you are confused. I am too and I am a good electrician.
Here is what I would do. DISCONNECT EVERYTHING START FROM SCRATCH WITH ONE CIRCUIT AT A TIME. 1. Connect battery ground. I would do 2 or 3 of em - one to starter motor mounting bolt (it is your heaviest load use 2/0 weld cable). One to engine block better yet the generator / alternator(kinda redundant I know use oh maybe 4 or 6) and one to frame use 4 or six. 2. Connect starter relay use 2/0 if you can get it to fit. 3. Wire starter relay (if foot stomp - ignore) to start run switch. Test in start (should run) check in RUN should not.
When you get that working right we will do next step.
Dan Bentler | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | Carlos I would listen to what these guys have to say. However in my case when I had a similar problem there was a short in the starter that was found when I took the starter to be tested. Re winding a starter is not a cheap proposition. Murray | | |
