2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Everyone, The other day I had the hood open with the engine running, and I noticed this rattle sound that would fade in and out. I pinned it down to (i think) the generator. Where can I get bushings for a 1962 235 generator? TIA, David
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The most likely source for a rattle that I know of is usually the water pump. When this happens, if you grasp the fan blades with the engine stopped, you can usually wiggle it on it's axis indicating worn bearings in the pump. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by truckernix: if you grasp the fan blades with the engine stopped, There you go giving away our secrets! Another diagnostic tool is the longggg screwdriver. Place the tip against the location where you think the sound is and hold the handle to your ear. Works like a stethoscope.
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | I haven't got a chance to check the waterpump, but what does a new one or rbuilt run for the 235? TIA, David
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Water pump is about $25 from NAPA.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2003 Posts: 7 Member | | Member Joined: Aug 2003 Posts: 7 | Yeah...the screwdriver idea works real well as long as you are CAREFUL...keep it away from ANYTHING electric...especially the generator...6V will give you quite a RAP, escpecailly if you have it rear your head...watch glasses too...You don't want them to arc weld to your HEAD...
On the brushes, I got mine for my wife's 54 at NAPA, about $2 each...
GOOD luck!
Jim | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | I like to Use short piece of garden hose, I've fried enough brain cells already. Take belt off of generator, try to turn pulley or move pulley up and down should sound clean or not have any play in it. popcorn The Truth is Out There (Good Luck) same way with water pump. | | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 |
