3 members (gswbbc, Rusty Shackleford, Gdads51), 102 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#7671 08/24/2003 2:33 AM
Hi Everyone,
The other day I had the hood open with the engine running, and I noticed this rattle sound that would fade in and out. I pinned it down to (i think) the generator.
Where can I get bushings for a 1962 235 generator?
TIA,
David
My truck don't leak oil, it just marks its teritory.
#7672 08/24/2003 2:56 AM
The most likely source for a rattle that I know of is usually the water pump. When this happens, if you grasp the fan blades with the engine stopped, you can usually wiggle it on it's axis indicating worn bearings in the pump.
1951 1 Ton Completed
#7673 08/24/2003 4:28 PM
Quote
There you go giving away our secrets! grin
Another diagnostic tool is the longggg screwdriver. Place the tip against the location where you think the sound is and hold the handle to your ear. Works like a stethoscope.
Fred
52 3600
69 C-10
#7674 08/25/2003 2:34 AM
I haven't got a chance to check the waterpump, but what does a new one or rbuilt run for the 235?
TIA,
David
#7675 08/25/2003 7:50 PM
Water pump is about $25 from NAPA.
Paint & Body Shop moderator
#7676 08/26/2003 1:46 PM
Yeah...the screwdriver idea works real well as long as you are CAREFUL...keep it away from ANYTHING electric...especially the generator...6V will give you quite a RAP, escpecailly if you have it rear your head...watch glasses too...You don't want them to arc weld to your HEAD...
On the brushes, I got mine for my wife's 54 at NAPA, about $2 each...
GOOD luck!
Jim
#7677 08/26/2003 2:33 PM
I like to Use short piece of garden hose, I've fried enough brain cells already. Take belt off of generator, try to turn pulley or move pulley up and down should sound clean or not have any play in it. popcorn The Truth is Out There (Good Luck) same way with water pump.
#7678 08/26/2003 6:25 PM
Cool smile Thanks everyone. smile cool
