| | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 13 New Guy | | New Guy Joined: Sep 2009 Posts: 13 | Does anybody know if a 55 2nd series cab will swap with a 58? I think the hood hinges are different, but will the 58 hood fit? Thanks. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the 55.2-59 cabs are the same external shape and dimensions, the hood itself is the same shape at the cowl - if you have the complete 58 front [58 hinges bolt on inners] then the main hinge difference is the mount points in the firewall are positioned slightly off so you need to hog out the mount holes on the hinges to get it aligned right .... good luck  Bill | | |
