6 members (Paul_WNC, Bill Hanlon, gswbbc, baldeagle, HandyAndy, Wally / Montana), 132 guests, and 2 robots.
Topics128,040
Posts1,055,475
Members48,424
#767199 07/31/2011 8:41 PM
Does anybody know if a 55 2nd series cab will swap with a 58? I think the hood hinges are different, but will the 58 hood fit? Thanks.
rrenner #767295 08/01/2011 1:03 AM
the 55.2-59 cabs are the same external shape and dimensions, the hood itself is the same shape at the cowl - if you have the complete 58 front [58 hinges bolt on inners] then the main hinge difference is the mount points in the firewall are positioned slightly off so you need to hog out the mount holes on the hinges to get it aligned right .... good luck wink
