1 members (Shade Baby), 152 guests, and 8 robots.
Topics128,106
Posts1,056,214
Members48,436
I have a front splash apron (sheet metal piece that sits behind the front bumper and butts up against the grill bars).
The part that would go up against the the grill is larger than the grill on my 1/2 ton. Any idea what it fits? Were 3/4 and 1 ton grills the same as 1/2 ton?
Will be listing it for sale and would like to list it accurately. I can take pictures and measurements if needed.
Thanks!
1950 3100 Project-just getting started
What year?
1.287 Panel in this illustration
Years and part numbers.
It looks like the same panel works on all sizes of trucks?
54 is different than the earlier ones right?
•1952 Chevrolet 3800 pickup
---All pictures---
a picture is worth a thousand words. could it be a GMC piece? he asks hopefully.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Yes, the 54/55st Chevrolet truck panel is different from the 47-53 panel (as shown for the 54 in the Master Parts Book link, above).
The GMC panel is different from Chevrolet. Maybe someone has GMC info (I am not near my GMC MPB).
GMC stone shields are different than Chev and are found in the 11.0540 group. However the illustration is in the 10.00 sheet metal section. 1953 and earlier is different than 1954. It appears that a 1954 COE does not use a stone shield. All of the GMC p/n start with 22 or 23.
I'm not surprised that it looks like it is wrong in a mock-up layout. As you bolt things together and tighten them down the geometry of the piece will change. With all the dents in the grille I would guess that the pan in question is the only piece that is right.
1953 Chevrolet 3600
I tried it on my actual truck (1/2 ton) with grill and bumper bolted on and it does not fit.
Anyone else have an idea what it is for?
I believe it's a 1.5 ton up splash apron,judging on how it mounts.If I remember right,on a big bolt the the mounting bolts slip through the bumper brackets.
Tim
1951 3100 Chevrolet
I believe that splash apron is the same as the one on my Chevy '50 COE. The key is the attachment brackets on the underside which are different than the 1/2 ton. The attachment bolts go through the bumper brackets in a vertical fashion, rather than the horizontal orientation in the 1/2 ton. Thus, it should fit 47-53 1 1/2 and 2 ton trucks (standard cab and COE)with the large channel bumper.
The rectangle with 2 holes is for the license plate holder and the other 2 are non factory, probably to mount signal lights.
Email or message me through this site as I have a friend looking for a decent one.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
