7 members (Otto Skorzeny, klhansen, Hotrod Lincoln, 3800GUY, farmallb, Rustnut, 1 invisible),
70
Mod | | | Forums66 Topics128,079 Posts1,056,301 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | I decided I'm going to split the exhaust on my 235 while the trucks basically apart for restoration. I can get Fentons for around $250 but saw tube type selling for $132. Weigh in guys....pros/cons?
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Fentons are reproduced castings, but work as originals. Tubes are fine too. Just depends on if you want the period look or not.
Drew
| | | | | Joined: Feb 2004 Posts: 29,822 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,822 | Tube headers burn out, and/or leak at the gasket area where they meet the head. They also increase under hood temperture and noise. The cast iron ones should work better and last longer. Jerry
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | What is the advantage of splitting the exhaust without going dual carbs?
I am sure there is some but what percentage power increase is associated with the dual exhaust as opposed to dual carb and dual exhaust | | | | | Joined: Feb 2004 Posts: 29,822 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,822 | The firing order on a inline six is 1-5-3-6-2-4. With a split exhaust, there is 240 degrees of crankshaft rotation between each exhaust pulse in the manifolds and pipes. The exhaust pulses in the manifolds go front-rear-front-rear, etc. There's no crowding of exhaust pulses, and plenty of room in each pipe for the flow from individual cylinders. Spliting exhaust on an I-6 actually makes some sense. Dual carburetion is just eye candy unless a great deal of engineering and tuning goes into the process. Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Spliting exhaust on an I-6 actually makes some sense. They sound real nice, too.
Bill Burmeister | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Thanks Jerry As always, the detail of your knowledge is impressive.
I would like to go with a dual exhaust at some point. The thought that I would have to go dual carb as well to get the benefit always turned me off (tuning one carb is enough work for me)
I would still need to get or build a set up to warm the intake though right. As I would lose my heat riser
Rich
| | | | | Joined: Feb 2004 Posts: 29,822 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,822 | If you can find an original Corvette 235 dual manifold, it's got the same heat riser system the single-pipe manifold uses. They're scarce and pricey, however. A good welder can build a split exhaust setup from a single, but it's not as effective as a factory or aftermarket dual system. Jerry
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The firing order on a inline six is 1-5-3-6-2-4. With a split exhaust, there is 240 degrees of crankshaft rotation between each exhaust pulse in the manifolds and pipes. The exhaust pulses in the manifolds go front-rear-front-rear, etc. There's no crowding of exhaust pulses, and plenty of room in each pipe for the flow from individual cylinders. Spliting exhaust on an I-6 actually makes some sense. Dual carburetion is just eye candy unless a great deal of engineering and tuning goes into the process. Jerry For this reason I believe the ones I have made would show little or no difference in performance compared to Fenton’s and/or the Corvette version and probably have better cold start driveability than the former. D.I.Y. info here.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
