BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,780 Posts1,039,296 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Aug 2009 Posts: 311 'Bolter | 'Bolter Joined: Aug 2009 Posts: 311 | Anyone have any suggestions on building a hand crank for a '48 liftmaster with a 235? | | | | Joined: Aug 2009 Posts: 311 'Bolter | 'Bolter Joined: Aug 2009 Posts: 311 | Sorry the truck is a 1948, 4100 series Liftmaster (emblem on the hood) with a factory 235 engine. It does not say Thriftmaster on the motor, and it is outfitted with the hand-crank fitting on the balancer. I want a hand-crank to turn the motor to adjust the valves. | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | Look thru this album (3pages) Curt, there are dimensions and pictures of how to make your crank. All you need is a three foot length of 3/4" round stock and a dowel pin. http://www.pbase.com/dennygraham/accessories&page=all Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | 801curt,
Can you post a photo of the emblem on the hood? The 4100 series might have a non-GM body.
Can you post a photo of your truck?
Denny's instructions should be excellent for making a crank. The Chevs of the 40s crank (the link I posted above) should also work fine.
You might be able to turn the engine, to adjust the valves, by simply putting the engine into neutral and turning the fan belt (and/or) the harmonic balancer by hand.
| | | | Joined: Sep 2002 Posts: 466 'Bolter | 'Bolter Joined: Sep 2002 Posts: 466 | Denny did you ever crank yours over and start it? It must take some Popeye arms.
The old man used to start "make and breaks" marine engines by hand, sometimes they would kick back and break your arm. | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | Nope, never had the guts or upper body strenght to start it. I use the crank when I'm adjusting the valves or setting the initial timing. But as Tim pointed out, you can also turn it with the fan as long as the belts aren't slipping. I can turn mine and the short block was just rebuilt, bored, new pistons and all, and the engine hasn't been started yet so it's pretty tight. Denny Graham Sandwich, IL
| | | | Joined: Sep 2007 Posts: 461 Shop Shark | Shop Shark Joined: Sep 2007 Posts: 461 | A good 1/2 breaker bar and appropriate 6 point socket will do the trick as well.
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | 6-point socket? To turn which bolt (on a stock 216/235 and most 261s)?
| | | | Joined: Jun 2005 Posts: 388 Shop Shark | Shop Shark Joined: Jun 2005 Posts: 388 | I'm not positive about the years, but after Chevrolet quit putting the hand crank fitting on the balancer, the balancers had a nearly-square hole that would accept a 3/4" square drive breaker bar or ratchet. These could slip in between the radiator and the balancer, and it made it quite easy to turn an engine. I still have the balancer with that fitting that came on my 1953 235. I recall using the method on several engines when I was working as a mechanic in the fifties and sixties. I just went out to my shop and looked at the balancers on two later 261s (post 1958s) and they do not have the square hole. The last time that I built a 261 in 2006 I tapped the crankshaft snout for an ARP 1-1/8" cap screw. This makes it easy to rotate the engine, with all of the spark plugs in and 11:1 compression. I also used to use a scissors screw jack handle to rotate my 1948 216 back in 1955.
Hoyt | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 |
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Thanks, Hoyt & Denny,
3/4" male square drive fits my 1954 harmonic balancer.
| | | | Joined: Mar 2007 Posts: 864 Shop Shark | Shop Shark Joined: Mar 2007 Posts: 864 | The original crank pulley had a 45 degree slot so that it would kick out the crank handle on start up...
if you try to use a speed handle or something else you will have a
dangerous whirling Dervish that will seriously hurt some one if you use it to start the engine....Ok to roll her over for valve adjustments or setting points... | | | | Joined: Mar 2011 Posts: 457 Shop Shark | Shop Shark Joined: Mar 2011 Posts: 457 | Denny, did you cold bend the crank or use heat? I need to make one of those!! Thanks, Ken
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't think anyone is advocating starting one of these with a 3/4" drive breaker bar Dave, at least lets hope not. Most of us aren't man enough to hand crank a Stovebolt anyway.
Yes Casey, heat or else you won't get a nice tight bend.
| | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | Wrench Fetcher Joined: Jul 2010 Posts: 66 | Denny, Thanks for posting crank photos. Are the dimensions close to the original style crank? Also, a stupid question. Is the hand crank bracket in your pictures for crank stowage? Or does it mount behind the grille to support the crank when you're starting the engine? Thanks, Dave Evans Wheaton,IL | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes those dims should be quite close to the original cranks. The bracket mounts to the center bolt that supports the center of the gravel pan. I believe those brackets are avalable from some of the vendors like Chevs of the 40's but kind of pricy. If you have a drill and file you can make your own by cutting out a pattern from cardboard to get the fit right.
| | | | Joined: Mar 2011 Posts: 457 Shop Shark | Shop Shark Joined: Mar 2011 Posts: 457 | Got my 3/4" steel rod today, and marked it with approx. dim., and it sure looks like it might hit the bumper!! No way to know if my bumper is in correct position, and I can tell brackets are slightly bent. May have to fudge 3/4" or so for the first bend, making throw or handle slightly shorter, but shouldn't be a problem. Never bent anything this thick before, so it's a learning experience. Seems to be a lot of interest, so I'll keep everyone posted.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | Plenty of room on the stock AD front end Casey. Maintain the longer dimension by making the first bent on it and keep the bends tight but not so tight you tear the metal making the bend. That way if you're off a bit on the dimensions it will only show up in the handle being a scoch to short. Denny Graham Sandwich, IL
| | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | Wrench Fetcher Joined: Jul 2010 Posts: 66 | Thanks Denny. I just finished it. Heated it to cherry red at the bends and it was easy. | | | | Joined: Mar 2011 Posts: 457 Shop Shark | Shop Shark Joined: Mar 2011 Posts: 457 | 52-3100, did you bent it in a vice once you got it red? Or some other way...Thanks.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | Wrench Fetcher Joined: Jul 2010 Posts: 66 | 40casey,
I clamped it in a bench vise, heated it quickly to cherry red with oxy-acetylene torch exactly where I wanted the bend, and bent it. When I bent it, I slipped a piece of 3/4 conduit over the end to be bent so it wouldn't bend in an arc. It ended up perfect.
Dave Evans 52_3100 | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | Glad it work out fur ya Dave, a few buck at the hardware store and a few minutes in the shop and ya just saved your self fifty bucks.
Denny G
| | | | Joined: Jun 2012 Posts: 85 'Bolter | 'Bolter Joined: Jun 2012 Posts: 85 | Built hand crank per Denny’s photos, thanks Denny.I did use a 5/16” dowel, better fit on my balancer. Very difficult to turn engine, small handle displacement does not give you much torque. So yesterday got a 1/2” drive 3/4” socket. Drilled 3/4” round stock for the 5/16” pin, welded to socket. Easy turn in shop now. See flicker link. | | | | Joined: Feb 2019 Posts: 4,100 AD Addict & Tinkerer | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,100 | So yesterday got a 1/2” drive 3/4” socket. Drilled 3/4” round stock for the 5/16” pin, welded to socket. Easy turn in shop now. See flicker link. I’m a bit confused. Did you cut the handle off of the 3/4” round stock and weld the 3/4” socket in its place or did you fabricate a whole new adaptor to use with 1/2” drive extensions?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | Joined: May 2015 Posts: 9,830 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 9,830 | Click the link in Mikeybakken's signature for a picture of the adapter he built. It'll become very clear.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | Joined: Feb 2019 Posts: 4,100 AD Addict & Tinkerer | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,100 | Very clear Kevin, thanks!
