0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | I'm hoping someone can help me. I had no lights working what so ever on my 1954 Chevy truck when i got it. The light switch was completely rusted up so i replaced it with one of the universal ones for the stovebolts. Does anyone know where i can find a wiring diagram for the universal? They say it works with some changes to the wiring, as there are less terminals that there where on the original. Also, I found the tail and brake light fuses on the firewall, but i have no headlights, park, etc. Is there another fuse block somewhere? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'm hoping someone can help me. I had no lights working what so ever on my 1954 Chevy truck when i got it. The light switch was completely rusted up so i replaced it with one of the universal ones for the stovebolts. Does anyone know where i can find a wiring diagram for the universal? They say it works with some changes to the wiring, as there are less terminals that there where on the original. Also, I found the tail and brake light fuses on the firewall, but i have no headlights, park, etc. Is there another fuse block somewhere? Does anyone know where i can find a wiring diagram for the universal?If the "universal" did not come with installation instructions and/or letter-labels near attachment screws, you might want to contact the seller to ask if they have information. Here is the wiring for the original switch. Here is a 1954 wiring diagram that should show you the wire colors for the different circuits that are wired through the light switch. Also, I found the tail and brake light fuses on the firewall, but i have no headlights, park, etc. Is there another fuse block somewhere? It looks like most of the circuits that go through the light switch are protected by a circuit breaker inside the light switch. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Should be able to figure it out with a continuity tester (multi-meter).
| | | | | Joined: Nov 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 150 | Thanks guys, I appriciate the help.
Darren. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Darren: I also have a 54....double check the wire connections on the inner fender on both sides. On the drivers side.. the wires from the light switch will terminate on the inner fender torwards the front at a multi-connector terminal ( can't remember the real name). Then a separate length of a wire bundle will attach to the terminal go across the radiator area to the passenger inner fender to another multi terminal. Wires go from the terminals to parking lights and headlights on both sides. Make sure there is a good ground.
If you need to replace the wiring harness...Chevy classics has one for about $ 150.00...very easy to install, all wires marked. When done you'll know wires are good and you won't have to worry about faulty previous Owner makeshift wiring.... | | |
