7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny),
102
Mod | | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 27 | I have the chance to get an automatic tranny from a '96 S-10. Would it be a good one for my '50 3/4 ton? I still have the 216 in it. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Probably not, that transmission is computer controlled to begin with, the bellhousing bolt pattern is different. These are just a few of the obstacles. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If you want an automatic, I would look at a Chevy Powerglide. Things will fit. However, I would think twice before putting an auto behind a 216 in a 3/4 ton. I'm afraid you would become a moving road block. | | | | | Joined: Sep 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 27 | So, to get my truck to run 55-60 mph, would it be best to swap axles instead of transmissions? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | An SM318 3 speed with a Borg Warner overdrive will do well with the 4.57 rears you have now. It will cut your revs by 30% in OD. 4.10 rears were available on some later 3/4 tons, but they are getting difficult to find and you don't gain much. Going to a much later complete rear axle will mismatch your front and rear brakes. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Or a T5 from an S10 pick up, if your not doing any heavy lifting with the truck... Or a 700R4 with an adapter plate... Or an NV4500 or A833... Lots of options. Some easier than others. T5 is easiest, but probably the weakest unless you get a World Class one from a Camaro and swap the tailshaft for one from a V6 S10...
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | That 216 will pull a load just fine at slow speeds. If you need more speed, swap the 216 for a 235 or 261, and find an OD transmission.
Was there a reason you are leaning towards an automatic?
| | | | | Joined: Sep 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 27 | The automatic was just an option I was entertaining because I was talking to someone about wanting to go the speed limit. The T5 from an S-10 sounds like the better swap. There are kits for making this swap, also. Right? It's a fun truck to drive as it is right now. If I can get it to run with the flow of traffic it would be even better. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Howdy neighbor. The T-5 is your best bet unless you are going to be doing some HD trucking, but I dont think you could hurt ona with a 216 unless you really tried. You dont need a kit. Just search the tech tips & posts. There has been A world of info on that swap. I have done 2 of them & i am in the middle of another one now. Mine have all been Task Force trucks which are a little easier. Bowtietim is on this website a lot. He is in this area & has done 2 of them in AD trucks. If you need help we will help you. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 27 | Thank you very much! There are a few mid-80's S-10 junkers sitting around in my area. I'll start on them. I found a list of favorable model numbers and their original applications. If I can find a tranny, what should I expect to pay? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I'm sure you realize the best bet is one with a mech. speedo drive. 88 up had the elec. speedo. My favorite is 1352-145. It has good ratios this kind of truck. The prices are all over the place. The pick & pull lots get $80-100. Full service lots want $250 up. An individual may be somewhere in between. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 27 | Is that model number stamped on the case? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Is that model number stamped on the case? NO. It is on a tag under one of the bolts that attach the rear houseing. Sometimes it is on top of the trans on a white sticker. It is ofteh hard to read on the tag. It seems they get rusty before they start leaking oil. It is in the lower left corner of the tag. It always starts with 1352-xxx. There are websites that break down that number tells what the application was & the gear ratio's. There is plenty of info on this website on the swap & a lot of fellow Stovebolters have done it & will help. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
