1 members (Thomaslb), 138 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#764868 07/23/2011 4:57 PM
I have the chance to get an automatic tranny from a '96 S-10. Would it be a good one for my '50 3/4 ton? I still have the 216 in it.
1950 Chevy 3/4-Ton Truck
jrp3 #764871 07/23/2011 5:05 PM
Probably not, that transmission is computer controlled to begin with, the bellhousing bolt pattern is different. These are just a few of the obstacles.
don stocker #764877 07/23/2011 5:45 PM
If you want an automatic, I would look at a Chevy Powerglide. Things will fit. However, I would think twice before putting an auto behind a 216 in a 3/4 ton. I'm afraid you would become a moving road block.
crenwelge #764921 07/23/2011 8:43 PM
So, to get my truck to run 55-60 mph, would it be best to swap axles instead of transmissions?
jrp3 #764934 07/23/2011 9:27 PM
An SM318 3 speed with a Borg Warner overdrive will do well with the 4.57 rears you have now. It will cut your revs by 30% in OD. 4.10 rears were available on some later 3/4 tons, but they are getting difficult to find and you don't gain much. Going to a much later complete rear axle will mismatch your front and rear brakes.
crenwelge #764962 07/23/2011 11:14 PM
Or a T5 from an S10 pick up, if your not doing any heavy lifting with the truck... Or a 700R4 with an adapter plate... Or an NV4500 or A833... Lots of options. Some easier than others. T5 is easiest, but probably the weakest unless you get a World Class one from a Camaro and swap the tailshaft for one from a V6 S10...
Highflyer #765029 07/24/2011 3:54 AM
That 216 will pull a load just fine at slow speeds. If you need more speed, swap the 216 for a 235 or 261, and find an OD transmission.
Was there a reason you are leaning towards an automatic?
The automatic was just an option I was entertaining because I was talking to someone about wanting to go the speed limit.
The T5 from an S-10 sounds like the better swap. There are kits for making this swap, also. Right?
It's a fun truck to drive as it is right now. If I can get it to run with the flow of traffic it would be even better.
jrp3 #765472 07/25/2011 8:11 PM
Riding in the Passing Lane
Howdy neighbor. The T-5 is your best bet unless you are going to be doing some HD trucking, but I dont think you could hurt ona with a 216 unless you really tried. You dont need a kit. Just search the tech tips & posts. There has been A world of info on that swap. I have done 2 of them & i am in the middle of another one now. Mine have all been Task Force trucks which are a little easier. Bowtietim is on this website a lot. He is in this area & has done 2 of them in AD trucks. If you need help we will help you.
1972 Chevy c10 Cheyenne Super
Thank you very much! There are a few mid-80's S-10 junkers sitting around in my area. I'll start on them. I found a list of favorable model numbers and their original applications. If I can find a tranny, what should I expect to pay?
jrp3 #765534 07/25/2011 11:07 PM
I'm sure you realize the best bet is one with a mech. speedo drive. 88 up had the elec. speedo. My favorite is 1352-145. It has good ratios this kind of truck. The prices are all over the place. The pick & pull lots get $80-100. Full service lots want $250 up. An individual may be somewhere in between.
Is that model number stamped on the case?
jrp3 #765726 07/26/2011 3:02 PM
Here's a good tech article from the HAMB about T5 swapping.
http://www.jalopyjournal.com/forum/showthread.php?t=171291
jrp3 #765802 07/26/2011 7:50 PM
NO. It is on a tag under one of the bolts that attach the rear houseing. Sometimes it is on top of the trans on a white sticker. It is ofteh hard to read on the tag. It seems they get rusty before they start leaking oil. It is in the lower left corner of the tag. It always starts with 1352-xxx. There are websites that break down that number tells what the application was & the gear ratio's.
There is plenty of info on this website on the swap & a lot of fellow Stovebolters have done it & will help.
