2 members (Frank50, Joe H), 120 guests, and 1 robot.
Topics128,175
Posts1,057,056
Members48,460
Hoping you guys can help.
Had my 235 block machined at a local shop, block was cast in Dec. '56 and built in Jan '57. The block has solid lifters. The engine shop ordered a hydraulic cam and lifters, thus the hydraulic lifters are about 1/2 shorter than the solid lifters. The engine shop owner said the best way to solve this issue is to see if my block has "oil galley holes" for the lifters and if so get the longer pushrods. My issue is two-fold, #1 I'm a newbie and cannot readily identify what an "oil galley hole" is, and #2 the block is at my brother's house 30+ minutes away. My stress level is high over this latest issue and I'm hoping you guys can offer some wisdom to ease my mind.
My question: is there a year when GM started putting these oil galley holes in regardless of the installation of mechanical or hydraulic lifters?
Block info:
Engine casting #: 3837004
Engine casting code: L2856 (December 28th, 1956)
Engine serial #: T123H (assembled Towanda, NY January 23rd, 1957)
Head casting #: 3835913
Thanks.
Newbie
1950 Chevy 3100
From 55 to 57 GM built hydraulic and Solid cam engines. The engine shop is correct in that you need the oil galley holes. There will be holes drilled the lifter bores if it is a haydaulic block. The rule of thumb is that most Powerglide equipped cars from the era were drilled for hydraulics and trucks were mechanical lifters. There is always exceptions to the rule though. The only way is to check for the holes. The early hydraulic motors didn't hold up well anyhow, if you had a 58-62 block, I would say go for it. My advise is to make the engine shop eat the hydraulic valve train and get you the correct mechanical cam and lifters. You're better safe than sorry.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
1958 was the first year all blocks were drilled for hydraulics.
If you have the engine code that is stamped next to the distributor, it would tell you if it is a hydraulic lifter engine.
If it had the tall lifters from the factory, which are only available in solids, the block will not be drilled.
My Blog
Engine code states its a model 31-32-36-3800 Thriftmaster 235.
Newbie
1950 Chevy 3100
If it is a 1956/57 Thriftmaster truck engine, it was not set up for hydraulic lifters.
No 235 truck engines came with hydraulic lifters; however, as stated above, 1958 and later truck 235 engines were set up to be able to work with hydraulic lifters.
All 235 automobile engines from 1956 onwards came with hydraulic lifters.
The distributor drive gear should be of the same material as the camshaft.
Distributor drive gear identification.
A. Steel gear has plain shank.
B. Cast iron gear has groove on shank.
-Tom
1950 Chevy 3100 w/ 1956 235
