Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
8 members (IHPWR, GMCJammer51, DJHobbit'46Chevy, Danielbolt, Dragsix, RBs36, 2 invisible), 559 guests, and 1 robot.
Topics126,780
Posts1,039,295
Members48,100
Most Online2,175
Jul 21st, 2025
Hi can the 19.5 rv wheels be used --with possibly opening up the center hub holes? do they share the same 5 bolt pattern?
I've heard of people using them. Check these posts out...
19.5" Wheels
and
Check Grigg's comment
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
You might be able to use them.... if they fit over your drums. Only way to know for sure is try.
Bolt circle will be the same 10 lug on 7.25". Center hole on the19.5" wheels will be 5.25" so you'll need some bushings to adapt your 4.75" hubs.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Wouldn't fit my 48 4400....
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.039s Queries: 14 (0.036s) Memory: 0.6087 MB (Peak: 0.6465 MB) Data Comp: Zlib Server Time: 2025-09-22 20:45:39 UTC
Valid HTML 5 and Valid CSS
